Losing my mind. Arcing problem
Testing compression next and putting on a random opti i had laying around. Dunno when. I havent touched it in over a month. I dont even want to mess with. Really just want the car gone now hate to say it. lol dont feel like putting up with this problem
If it does, start removing stuff from the plugs back till it stops arching?
Just throwing up an idea, no idea what might be the issue.
obviously the first thing i did was try a spare plug wire, which ran a lil' better for a short time, and then started arcing even worse than the old one.
turned out that the gap on a spark plug had filled with shaved ringland material. it eventually burned itself some new gaps in the coil, coil wire, and affected plug wire, and managed to jump them all.
actually ran alright just cruising. it must have been sparking just a tiny bit despite all that mess, enough to keep running till you put load on it.
