PCM maybe
I was investigating the constant failure of the PCMs in my 94, and contacted everyone that I could find about the subject. It was an engineer at GM that clued me into the fix when he suggested that I use the OBDII computer vice the OBDI as the cure. Unfortunately, shortly after that, GM stopped talking to me. Hmmmm....was I on to something here? You betcha!
Here's the skinny on this. It seems that all of the OBDI computers used in all LT1 powered cars in 1994 and 1995, except for the Corvette (they used a different computer) will fail--this according to every rebuild company that I talked to. This particular PCM is responsible for more failures than ALL other power train computers combined (at the time). Hard to believe? I thought so, too. In fact, it was a year later that I took the chance and bought a known good OBDII computer in desparation. I studied the entire harness and all the connectors. There are only three differences and they aren't a problem. The OBDII PCM has a connector for crank triggered timing, a connector for the EGR and a connector for the third O2 sensor, that's it. The harnesses and connectors are otherwise identical. All the guy that loads the software into the PCM has to do is turn off that part of the software--just like turning off the CAGS.
The OBDII computer uses two 32 bit RISC processors, the OBDI uses two 16 bit RISC processors. That means that OBDII PCM computes mathmatical solutions about 3X as fast. It also has 3X the memory and can handle 15,000 more lines of code. Installing your OBDI software on this computer is just about like supercharging the engine since the OBDI software is based on a 16 bit language and uses, I think a 16 bit address vice 32 bit address in the OBDII. What's important to you is that GM rates this single change as worth 10 hp to the engine. This is solid and REAL hp.
It is amazingly easy to make the change. The hardest part is unbolting the old one, removing it and throwing it in the garbage can. PCMforLess.com can do the necessary software mods for you for about $100. Mine was the first and worked beyond all expectations. There is so much wrong with the OBDI that most people just accept the way the cars run as that is the way they are supposed to run. It ain't so. And yes, my car passed the SMOG test on a rear wheel dyno. Since the software was keyed to my VIN number and was correct for the car, nothing showed up on the SMOG computer.
It's just my opinion, but I think GM stopped talking to me, becuz they are aware of this problem. Being aware of it, they should replace all the defective PCMs, but that would cost a fortune and they don't want to pay for it. Better to just let those cars rust away in a wrecking lot and disappear inside a crusher. There should be a class action lawsuit against GM, but it will never happen.
I don't know why so many put so much faith in wild crap like that they read on the Internet, which is a vast sea of mis-information. Much more bullshit than truth floating around.
i just had pcm communicator hooked up and when i started the car it was at 4048knock count- After about 2or3 min I was up to 5134 then after about 4-5min it was up to about 5434. Sound normal or does that sound high or like that may have something to do with this? the Knock Retard the highest reading when just revving the car in park was .6-1.2 degrees.
Any competent tech could find a mis-fire. Injector driver issues are about the only thing in an LT PCM that would make one miss. Very easy to test with a DSO. Bad or missing wave forms will tell the tail.
