Rear Caliper Bolt
Old Jul 27, 2013 | 05:05 PM
lt1_2buku's Avatar
Default Rear Caliper Bolt
Anyone know what size hex it is for the bolt that holds the E brake cable to the caliper? Found a lot of suggested sizes through search but nothing def.
Old Jul 27, 2013 | 06:04 PM
Camaro350Z28's Avatar
last i knew the cable wasnt bolted on? just has prongs holding it in? or you trying to remove the whole assembly
Old Jul 27, 2013 | 09:18 PM
lt1_2buku's Avatar
Thanks. I didn't realize the caliper came with the spring assembly. All is good.
