95 T/A cooling question
All stock cooling system, 190 stat. Water only in system.
When I got to drive it last summer, the car warmed up to ~200 and held steady as I drove, through town etc. On the freeway, extended 65+mph, temp climed +10-20 degrees. Back on secondary roads, temp would slowly drop back to ~200.
When I start any drive, I go through 6-7 lights at slow speed before I get to open roads. temp stays steady. However, after driving and coming from open road, going through thouse same 6-7 lights at slow speed, the temp climbs steady +20-30 degrees!
On any road, as soon as I turn on the A/C, temp climbs steady - up to +30 degrees, even driving under 50mph, not too hot day, temp runs 220+ A/C on, ~200 A/C off.
Here is what I've done since:
1. new engine and heads, never removed the radiator, no cooling changes.
test drove and during tuning - same water temps as before.
2. tested fans - come on as programmed and come on with A/C switch.
Changed fan on/off settings with no noticable change in temp while driving = same as before
3. removed 190 stat, installed 160 stat. lowered fans on to be @175, kick off when under 160 (exact settings vary slightly)
Driving temp lowered to ~180 while warmed up and first driving. On freeway temp climbs to ~200, same dramatic temp climb when A/C turned on. Also temp climbs after a drive going through 6-7 stop lights to my house. the stop and go at slow speed AFTER driving awhile, temp climbs +20-30 degrees.
Pretty much same issue, but at a lower starting temp.
4. changed out radiator for new stock unit. filled 50/50 water/antifreeze mix.
Warmed up and first drive at ~180 as before. Freeway 65+mph climbed to ~200, turn on A/C instant climb to ~230 degrees. A bit worse with antifreeze and new radiator.
5. drained and filled with distilled water and WaterWetter. Sat idling for 30 minutes during flush/fill steady at ~180. no test drive (raining). I can see the water pumping steady stream into radiator as it is filled. Turned on A/C = instant climb to 200 degrees then I shut it all off. Fans were running.
So, since I bought this car and made several changes - the temp climbing issue through stop/go traffic and when A/C turned on has remained constant.
Any ideas?
*temps noted are both by dash gauge and laptop logging w/Datamaster.
FYI - the last fill up with water/WaterWetter, sitting still in my driveway - steady temp for 30+ minutes, turn on the A/C = instant temp climb. no drop in engine idle to speak of, just compressor clutch kicks in, fans are on - but temp climbs just sitting still (also during driving)
Air has been bled several times, at each system change.
The temp is responding to the stat change - just still temp climbs under 3 situations:
1. when A/C is on
2. when traveling at freeway speeds for length of time
3. during stop and go traffic AFTER some normal driving.
Insight or experience with any one of these is appreciated.
I thought the temp climb issue would be resolved with my engine/head rebuild.
I lowered the compression a little and relaxed the tune for less risk of ANY damage.
It did not change this temp climb issue at all..
As for the temp going up with the AC on, the condenser gets hot, making the air coming through radiator hot.
Tired electric cooling fans that don't run as fast as they should, thus moving less air.
I guess you lowered the cooling fan control temps for the 160 'stat?
When new radiator was installed, we did clean the condenser fins of what was mostly just road grime. No oil leaking present anywhere, all dry.As for the temp going up with the AC on, the condenser gets hot, making the air coming through radiator hot.
I thought this, but why so extreme in this car? I've owned 10 other 4th gens, never a hot running issue...Tired electric cooling fans that don't run as fast as they should, thus moving less air.
Now this concerns me because I just don't know about condition/speed- only that they turn on and spin in the proper direction.I guess you lowered the cooling fan control temps for the 160 'stat?
Yes I did
But on this 95, I really hope to hit the mark on my next try.
Can I remove and test my fans somehow? Or is it pretty safe to just replace them as my next step?
hear the difference and probably feel it on your hand held behind them while running, compared to another that has no cooling problems.
Real scientific, right? Sorry that I know of no test.
It actually does not get to overheating - just climbs ~30 degrees from normal operating temp under the 3 conditions listed previously.
I had a kooky test idea - put a voltage booster (as used with fuel pumps) to the fans power source. Perhaps that would tell me something...
I suppose I could try and raise the radiator cap pressure a little..I have pressure checked the system and found no leaks.
