LT1 Camaro Front Pads
Old Aug 18, 2013 | 07:41 PM
dapsaute's Avatar
I would like to get a set of good pads and rotors and start from there.
I do plan on doing a LS1 front conversion, maybe next year, but if I can buy another year to do other things, that's the way I'll go.
There is a salvage yard 45 minutes from here where I can get bare 98-02 spindles for $45 each. The RF hub has 47K, the LF hub 15K (replaced due to bad ABS sensor), so I plan on reusing those.
The LS1 stuff is as big as I plan on using...I'd like to keep the 16" salad shooters for winter storage.
Thanks!
Dave
Old Aug 20, 2013 | 07:28 PM
YAC-WS6's Avatar
Could always run a c5 conversion. keeps up much better with more power. with a car sitting that long, I'd bleed the brakes, check the calipers, brake fluid can turn into a gooey mess if it sits for too long.
