weird knocking sound...
So we can only imagine what really happens but my guess is if the large spring breaks or flattens the piston won't pump up any oil and if the rocker/p-rod continues to be adj it will turn solid and hold the vlv open- no oil pumped up.
Other case the weaker small spring fails/flattens and oil is forced back into the galley - again just an assumption.
You do have several other tiny parts but other than the piston they aren't very active inside the lifter - so of course if the piston busts or seizes no oil will flow.
Hope this helps ya SQUEEG and sorry if i attracted u some flak here, just need to get the word out and maybe save some guys engine he has put a fortune in,
cardo
And i have had that experience of rolling in new bearings also. So like i can't help others???
cardo
U need to pull that lifter and look at the cam lobe (and roller surface).
U can google for your self but this is from car craft mag: We've measured normal lifter travel in a stock hydraulic roller lifter at roughly 0.120 inch, and Comp Cams' Billy Godbold says he's seen cheap lifters with as much as 0.180 inch. That means 1-1/2 turns (on a 0.120-inch depth) places the lifter piston roughly halfway in terms of piston travel within a typical hydraulic roller lifter.
So that lifter looks more than 0.180" deep but pix can lie. And fuel puddled up behind the vlvs like the injectors are leaking by. I think by '95 the injectors fired sequentially rather than batch but not sure and not gonna look it up. Do u have engine run-on? Dieseling at all?
cardo
If your cam lobes look good then i would say u got lucky and replace the lifters. Adj from cold engine will require to use the finger the p-rod method and see what results.
Just my opinion is to replace the lifters and try again before an engine pull.
Good luck on what u choose,
cardo
EDIT: should I buy all the lifters? parts store priced them at $265 but I think I paid around $120 for ls7 lifters at the dealer I'll have to wait til tomorrow to call the dealer
