Tuner Pro Speedo multiplier
Old Aug 22, 2013 | 12:43 PM
draggin97s10's Avatar
Default Tuner Pro Speedo multiplier
Can anyone tell me how to calculate the multiplier in tunerpro?
Old Aug 23, 2013 | 11:32 AM
1995blacktattop's Avatar
I changed rear gears in my car a few weeks ago and had to re calibrate my speedometer in tunerpro. here's a thread on ls1lt1 that explains the 4 values and what needs changed. luckily someone from that site used tunercat's speedometer calculator tool and give me the 4 values i needed changed.
http://www.ls1lt1.com/forum/pcm-tuni...nerpro-rt.html
There is a calculator tool you can use, but i think it only gives you 3 of the 4 values you need. you can fiind it in post #9 in the link below
http://www.gearhead-efi.com/Fuel-Inj...rmation-EE-EEB
here are the 4 values you need to change to calibrate the speedometer as seen in tunerpro
Attached Thumbnails Tuner Pro Speedo multiplier-tunerprospeedometervalues.jpg
Old Aug 26, 2013 | 10:42 AM
Thanks...got it figured out this weekend.
