Spark plug wire question.. Car running rough
Old Aug 25, 2013 | 08:55 PM
94 z28 A4's Avatar
Default Spark plug wire question.. Car running rough
Ok so picked this car up last weekend and it has ran perfect until about 2 days ago. I get in it to go to work and its running rough almost like a spark plug wire is disconnected. So when I got time to look at it I started checking each one and came to one that just came right off like it wasn't snapped on. I tried pushing it back on until it clicked but it never did. I squeezed the terminal closer together but I think i did it too much and had to separate it a little more. Anyways it will go on and fit kinda tight but still doesn't "snap" on. I'm almost positive it's this wire that is causing the problems because just to check to see if it was that plug I unplugged it completely and cranked it and it seemed to run about the same. All the other wires take a goo amount of force to pull off except for this one wire. Do you guys think this wire is the one causing it? My dad has same year lt1 and has some extra wires so I'm gonna get one of those and see if that solves it. Just wanted some more input on what y'all thought.
Old Aug 25, 2013 | 09:00 PM
93Euphoria's Avatar
Do you hear it arching when the motor is on? I had the same problem when the boot would fall off sometimes and misfire. Try moving the wire back & forth to get it on. Sometimes just pushing it in isnt enough.
Old Aug 25, 2013 | 09:13 PM
shbox's Avatar
You also can always ohm the wire to see if it has continuity.
Old Aug 25, 2013 | 09:59 PM
94 z28 A4's Avatar
When I first crank it you can hear it arching a little and hear the exhaust sputter. Shoe box what is ohm?
Old Aug 25, 2013 | 10:09 PM
shbox's Avatar
Ohms...you know, when you put a meter on it and read resistance (in ohms). It should compare to other plug wires of the same length.
Old Aug 25, 2013 | 10:18 PM
94 z28 A4's Avatar
Oh my bad I gotcha now. Ok I'll try that. Thanks man I appreciate your help! When I tried to originally crimp the terminal I believe I did it a little too much and I think some of the outer piece of the terminal might have came off. So that's one reason why I'm gonna try to put another wire on and see.
