Hate to ask this......
Old Sep 5, 2013 | 10:28 AM
Sabohead's Avatar
Default Hate to ask this......
But does a ls1 valve covers fit on lt1? Would like to put something different on the motor. I have a 96 Z28 6spd. Try to go easy on me please. I know I have a lot to learn. Thanks. Joe
Old Sep 5, 2013 | 10:36 AM
1995blacktattop's Avatar
i don't think so, but i think any gen 1 SBC valve covers with 4 center mount bolts work. that means anything mid 80s on up i think as i had an 83 T/A 305 that had 4 perimeter bolts rather than the 4 in the middle of the valve cover.
*edit*
just checked ebay and found this pic of aftermarket LS1 valve covers. no way those are fitting on an LT1. while they appear to have the same mounting holes, the shape of the valve cover itself is different. LT1's don't have rounded corners like that.
Old Sep 5, 2013 | 10:40 AM
Sabohead's Avatar
Ok. Thank you sir. I know there is a concern with the alt being right on top more or less on the valve covers. I like the (god 4 give me) Edelbrock no name ones.
Old Sep 5, 2013 | 02:07 PM
Ntimid8r7's Avatar
yeah you pretty much have to have valve covers made for a LT1 because of the alternator.
Old Sep 5, 2013 | 03:26 PM
VAformula's Avatar
Exactly, or you move the alternator and use any non ls1 center bolt valve covers.
Old Sep 5, 2013 | 03:41 PM
SS RRR's Avatar
Village Troll
For aftermarket VC's you can use standard sized ones if you grind a bit on the alternator. This is risky because it's dangerously close to some bolt or screw that is on the inside of the alternator. If the aftermarket VC's are stamped steel you can bang on them a bit to clear the alternator. It's been done countless times.
Old Sep 5, 2013 | 04:15 PM
93M6Formula's Avatar
Any center bolt valve cover from a 1987-2000 GenI or GenII SBC will fit. You would just have to have the alternator area notched out.
Old Sep 5, 2013 | 05:14 PM
Sabohead's Avatar
Thanks for all the input.
Old Sep 5, 2013 | 06:39 PM
devildog214's Avatar
lt1 corvette composite valve covers, a bit rare and pricy though. Other than that just look at summit.
Old Sep 6, 2013 | 08:42 AM
leadfoot4's Avatar
I liked the look of the Proform black crinkle VCs, but they don't clear the alternator. No problem, I thought, as I had access to a Bridgeport mill, and could machine a notch in the VC to clear the alternator. I then made a cover to clear the notch, welded it in place, shot the cover with black crinkle paint, and slipped them on.
What a waste of time and money..... The VCs just wouldn't stay tight, as the tops of them are made of a thin material, and flat, with no ribs for support. I wound up "snugging" the bolts every other day, in an effort to stop them from leaking, and after a month or so, the tops were warped inward, and the VCs useless.
They DID look great, however, while they lasted....
