spark plug wires
Old Sep 30, 2013 | 11:57 PM
Paul Bell's Avatar
That's MISTER MODERATOR
You may be one of the lucky ones who have a good set of Taylors. I suggested replacing them to eliminate the wire set as the cause of your problems.
Old Oct 2, 2013 | 10:37 AM
ROUDA's Avatar
ok put wires on and the pass side what a bitch I don't remember fighting it like that. any way bought accell 9000 just to see what happens and they are arching bad... and come to think it looks like a arch is behind the coil very small sparkly I could see
Old Oct 10, 2013 | 10:54 PM
ROUDA's Avatar
ok so update got new Delphi wires there all good also new coil. car is still missing doing the same thing I believe to see a tiny arch what looks to be around or under the water pump thoughts on this??????
Old Oct 11, 2013 | 12:26 AM
great421's Avatar
OP -
If you can actually SEE arcing behind the water pump (i.e. - in the location where the Opti is mounted on the engine), then you need to at least replace the Opti's cap and rotor, maybe the entire unit; but you will not know until you take it apart and inspect the unit for damage / water / issues.
Be sure to inspect / check / test the 4-pin Opti extension harness for issues too (Just unplug it and then look at the end and inside the Opti for evidence of problems).
Have fun!
Old Oct 11, 2013 | 10:17 AM
ROUDA's Avatar
oh boy ok thanks for the tips
