Prp ewp?
If there is nothing wrong with the mechanical pump and you do not want to run a double roller chain then you are probably better served sticking with it. The reliability on an electric pump is also highly debatable where some observe failure within weeks and others lasted years regardless of brand (I have had both situations happen to me).
I had a mechanical go at around 130k so they do last a while. Heres a ac delco "kit" for cheap ($77) but cant tell if its the whole pump or rebuild kit or not:
Good luck
cardo
Specs look similar to a CSR or Meziere, although I realize the flow rate isn't real world. I decided to stick with the mechanical pump since I found a used gear/shaft for $7 on ebay that is in decent shape. A new gear/shaft runs over $150 new, so that's why I was considering going ewp. My pump itself only as around 25k on it so I plan to reuse it for my build.
The mechanical moves more than enough, even the electrics are adequate at cruise. You have other issues like airdam folding over at speed or something.
