Something isnt rigjt...
Old Sep 13, 2013 | 07:09 PM
myltwon's Avatar
Originally Posted by shbox
This is what is should have, if it is a late 94 with the sensor behind the intake.
http://shbox.com/1/oil_pressure_sensor.jpg
The sensor with the bigger threads is what is used on an early 94 that had the sensor by the oil filter.
yup beat me to it, I have the earlier style.
Old Sep 13, 2013 | 07:16 PM
Puck's Avatar
Oil pressure dropping when revving is a very bad sign.
Drain the oil and check for bearing material...
Old Sep 13, 2013 | 07:21 PM
Quazz's Avatar
God I hope not.... This motor has 1.5k on it.
Old Sep 13, 2013 | 11:33 PM
The Outlaw Kid's Avatar
Originally Posted by Quazz
And my mistake , it was between 14psi and 16 psi.
Way too low.
This may be a dumb suggestion but check that your not leaking anything into your crank case. I had a 4.3 CPI s10 that leaked fuel into the crank case. It seemed to thin out the oil resulting in lower oil pressure.
Old Sep 14, 2013 | 08:12 AM
SS RRR's Avatar
Village Troll
If that's cold then that's bad.
The smell of fuel in the oil would be extremely strong.
Old Sep 14, 2013 | 02:38 PM
Quazz's Avatar
Yeah, oil is dirty, no strong fuel smell. I brought the filter to the builder today, there is a TINY bit of gold dust in the oil that came out of the filter, nothing that says failure though. Filter was cut open, it didnt have any excessive ammounts of metal in it. The Filter was a REAL short filter though, and looked wrong for the car. It was pretty damm dirty too. We are going to change the filter and see it that helps.
Old Sep 14, 2013 | 04:11 PM
Quazz's Avatar
Wow. Changed the oil filter out with a K&N filter, and now the stock gauge goes right to the 3/4 mark on a cold start. The filter that was on there was a pro-motive filter.... Says made by wix.
Im changing the oil as we speak, just to make sure there isnt excessive metal in it.
Old Sep 14, 2013 | 04:27 PM
Weird never heard of an oil filter doing that. Is it possible that the filter wasn't letting enough oil through? Glad you got it sorted out though.
Old Sep 14, 2013 | 04:29 PM
Yeah it did smell like fuel. It was just a thought from experience.
Old Sep 14, 2013 | 04:36 PM
BIGCAT7274's Avatar
cut that filter apart and find out why it failed before running that engine any more.
Old Sep 14, 2013 | 06:19 PM
Quazz's Avatar
Filter was cut, nothing in it really, just a bit of gold dust. The fliter element looked..... Deformed? Ill post a pic up, but no shavings or chunks of anything, just REAL dirty.
Old Sep 14, 2013 | 06:42 PM
  #32
Quazz's Avatar
I think the filter was too small, it collapsed internally, and wouldnt flow much. It probably made.the pump pressurize to the point of nypass, and it simply dumped most of the oil back into the sump.
Old Sep 14, 2013 | 07:27 PM
  #33
BIGCAT7274's Avatar
did you squeeze the oil out of the element then look at it? or did you just spread the pleats apart and look at it? "gold dust" does not sound right or good.
Old Sep 14, 2013 | 09:13 PM
  #34
Quazz's Avatar
We squeezed oil oit, we also spread all the pleats apart.to look for flakes/chunks. The gold dust was extreemly minimal, just a bit of a visible swirl when tipped the right way in direct sunlight. It was minimal enough where i couldnt get a pic of it, no matter how hard I tried. This is only the second oil change on the motor, and the first after the initial fill. This oil has roughly 2k on it.
