LT1 running great, then old problems reoccurring.
#41
I tried to send a message to Shbox but apparently, he has his messages turned off (which I understand with as many questions as he would get). So I'll ask all of you.
I've been on shbox.com and saw the directions on testing the opti harness. We disconnected the harness from the distributor at the opti end and tested it. All terminals checked good except for D. Instead of 60 ohms, there were only 11. We decided to check the pig tail that goes to the opti harness coming from the PCM so we could see if it was just the opti harness or something else. Well, the PCM pig tail was also 11 Ohms. Does anyone know why there were only 11 ohms coming from that Pig tail?
