rear end
Old May 3, 2004 | 06:50 PM
WannaZ28's Avatar
Default rear end
any suggestions on a good rear end thats not that high in price?
that moser 12 bolt is WAAAYY too much (2k)
Old May 3, 2004 | 07:00 PM
brandboZ28's Avatar
Unless you can find a good used 12 bolt or 9in, youre looking at about 2k or better when everything is said and done. Even the used ones are going for ~$1,500, at least the ones Ive seen.
Old May 3, 2004 | 09:05 PM
Vendetta's Avatar
Simple answer: No.
There's a Ford 9" rear assembly that's stronger, but more money. The best deal you'll find is on a used 12-bolt or 9", and IMO, you're better off just buying a new one.
Old May 3, 2004 | 10:25 PM
TSAEB's Avatar
I second that...but i think its worth it...just to put some higher gears is about 200, kit 100, and if u pay somone is another 200 and up...by a new 12bolt a lil over 2 grand and it comes with ur choice of gears...plus u can add slicks and launch at a crazy 4-5 grand...better 60 ft/ets....great for sleepers.
Old May 3, 2004 | 10:35 PM
lt1_sickness's Avatar
i had this problem to but some how can't say i came up with a 68' 12bolt with 411's out of a camaro and 2 12 bolts with 411's out of chevelles. but check out frankland they make strong rearends to little cheaper then mosser.
Old May 4, 2004 | 12:33 AM
brandboZ28's Avatar
I agree, its definatly worth it. Once you buy gears, an install kit, a rear girdle with stud kit, gear oil, and pay someone to install it, its worth it to just go ahead and buy the Moser for $2k and have the added assurance that you dont have to worry about a 10 bolt again. Then its bring on the slicks and...
