URGENT opti to pcm wire testing
As the title states I need to know where to test the wires between the PCM and the test connector on top of the motor.
I have the wiring diagram however I haven't a clue which wiring harness from the PCM to check or which pins go to the opti!
Please help.
I'm way further than that, I have 5 dtcs
High res fail
Low res fail
Est open
Est ground
Eprom checksum failure
Car won't turn over because it isn't getting the timing (I assume) so I'm checking the wires along the dtcs it trew at me.
If it cranks but won't start check out this link.
http://www.mainstreamtopics.com/foru...rt-diagnostic/
