Another lt1 misfire thread..please come inside
Well its been giving me problems lately.it appears it has a misfire at low rpms .
No backfires.
It shut down on it once an after a few tries it started.i belive the sparkplugs and wires are bad.
At WOT it seemed to work fine well sometimes.
Could sparkplug wires cause that?
Any input is appriciated.
After 160K I wouldn't be surprised if your opti was finall letting go. Opti, wires, and plugs are never a bad idea if you have a saturday to burn down.
Update
Car misfires on and off .did a wot today pulled good going nuts over the issue
Miss would be wires maybe plugs. What heat range plug are u using. Did u change the plugs lately? Any hi-po ignition mods?
But always check your codes first. U may have the answer waiting for u.
I had to change wires over 2 years ago and found a hole in 1 wire but the miss was hardly noticeable.
Do u have headers? Headers can burn up wires fast as u can replace them but i cant tell from your profile. I think i read its a 383 with exhaust mod?
cardo
