Changes to the 396CI, now with nitrous rings.
Old Oct 4, 2013 | 11:52 PM
OVA1's Avatar
WOW~
Old Oct 5, 2013 | 12:11 AM
noice's Avatar
The 8.75 was on a 100 shot. We upped it to 150 and ran a 8.69, just shy of the record.
Someone lined up next to us and was ******* on our car a bit. He blew his rear out as soon as he left. I helped the track officials clean up an picked up parts of his rear end.
Old Oct 5, 2013 | 07:17 AM
Tony Shepherd's Avatar
Nice job! That 60ft is killer! What is the raceweight? Tire size? 4 link and back halfed? On Alcohol and nitrous?
This gets me motivated to get back out there.
I guess you got that fuel pump issue fixed? LOL
Old Oct 5, 2013 | 09:30 AM
fex77k's Avatar
Yea it hung the front for a little bit. I was leaving off 35% on the progressive. it's 2120lbs with me in the seat. Tires are 16x33, full chassis car, Mark Williams 9" behind the 4 link. Yea alky and nitrous.
Hit em Up's Avatar
Damn that's getting it done right out the gate!! That 60ft is crazy good luck going for record!! Any video of runs?
Old Oct 5, 2013 | 09:42 AM
Nice!
that is 1,180 lbs lighter than my car. I am at 3,300 lbs.
I need to throw my engine in something like that!
Congrats on your new best. You have more in it ill bet.
Old Oct 5, 2013 | 09:46 AM
fex77k's Avatar
Cool
Nice!
Mike V needs to put his motor in for na, I bet that thing could run high 8 too. You would crush the record in my car.
Old Oct 5, 2013 | 09:59 AM
Mike V Ness to put his motor in for na, I bet that thing could run high 8 too. You would crush the record in my car.
LTX 2014
I will bring the engine. You bring the car. We can throw it in the night before the race.
Old Oct 5, 2013 | 10:29 AM
noice's Avatar
www.youtube.com/watch?v=rb9dZFViM5k
This was the 8.69, you can't really see the scoreboard though. The video isn't perfect as I was trying to watch the run more than record it.
Old Oct 5, 2013 | 10:44 AM
OVA1's Avatar
A set of FRESH and FULLY PORTED AFR 195 LTs
Would make that Monster DANCE!
OVA1s AFR 195 LTs are
FOR SALE!
(Find us Fast in the Classifieds…)
Old Oct 5, 2013 | 11:00 AM
transbird95's Avatar
Was someone talking about racing???
  #32
noice's Avatar
Another video, it was slower in the 60ft so either the track fell off or we were spinning.
Old Oct 5, 2013 | 11:17 AM
  #33
BIGCAT7274's Avatar
damn nice runs. looks like i get bumped down a spot on the list.
Old Oct 5, 2013 | 11:42 AM
  #34
Hit em Up's Avatar
Lol serious reaction time!! Car really moved out good job looking forward to more results!
Old Oct 5, 2013 | 11:52 AM
  #35
noice's Avatar
If everything is going right (leaving on the top bulb and using a 1 second delay) it will be anywhere from .015 to redlighting by a couple of thousands. Some of that is from the fact that you can see the bulb change faster at night. So there is something like 1.02 seconds delay from the top bulb to keep from redlighting.
Probably wont get a perfect reaction time for quite a while, but we have gotten some .005 times.
I should have given it the 200 jets last night.
Old Oct 5, 2013 | 08:14 PM
  #36
OVA1's Avatar
IMG 2401 - YouTube
DAM'! That car has a BEAUTIFUL LAUNCH!
Old Oct 5, 2013 | 08:40 PM
  #37
Motorvation's Avatar
Nice build. What Oil do you use? We run Brad Penn, no vacuum pump, no milk. Really good oil.
Old Oct 5, 2013 | 09:28 PM
  #38
noice's Avatar
I run Pennzoil 20W50, it is cheap. I'm going to switch over to Valvoline VR1 since it is the only race oil I can get that is stocked on the shelf local.
The think that was probably really causing our oil milk was most likely that we weren't leaning out the motor on the return road before.
Every pass we made there was about 1/2 a shotglass full of alcohol in the vacuum pump tank. If you keep your motor warm, that would most likely evaporate out.
Old Oct 5, 2013 | 09:29 PM
  #39
fex77k's Avatar
I run 20W-50 Penzoil, nothing special. I used to change it every 3-4 miles, but the vacuum pump sucks the alcohol right out of the crankcase. I get 2-3 tablespoons of alcohol every run, so I might try running it longer.
Old Oct 7, 2013 | 09:06 PM
  #40
noice's Avatar
With the way he has been updating the list lately, i doubt it will ever change.
