4/7 swap
If I were building another one I would do it for a high dollar (those cam core cost more) race engine due to gains seen by pro engine builders that have back-to-backed it. We are looking for every hundredth we can find. I would not spend the time & money to just change that. You would never know the difference in a street car.
Read more: http://www.hotrod.com/techfaq/113_07...#ixzz2hSj3ff9n
The op asked about the 4-7 swap. The engine builders I talk to tell me with the 4-7 swap only the 2-4 fueling issue isn't as bad as 5-7 was. It isn't that simple. Has to be the manifold. I know the fast Super Stock guys running single plane intakes on SBCs have a LOT of work in them, including altered divider lengths.
I had $3500.00 in the one I tested. My old Hogan was faster, and cylinder-to-cylinder air/fueling needed much larger corrections than my Hogan sheet metal. There are several fast LT1 SS guys running single planes with elbows in SS (we have to run stock TBs) but some may be faster with a Hogan. Your results may vary.
