looking for super or procharger for lt1
Old Oct 26, 2013 | 07:30 PM
madskillz2144's Avatar
Originally Posted by ahritchie
Good aftermarket ported heads would be my next choice. Sell the ported stockers and upgrade to some Ai ported trick flow 195cc or 215cc heads; big NA hp
http://www.advancedinduction.com/LTX...inderHeads.php
yea ill try some aftermarket heads instead of ported stock heads,imma do more suspension work now also,all new body bushings,mini tub also to do bigger rims and tires, but i still want a procharger might have to settle and put the spray back on,and maybe replace factory ported intake with this one http://www.ebay.com/itm/Fully-Ported-LT1-Intake-Manifold-Camaro-Corvette-LT-1-Impala-Caprice-Roadmaster-/161132826582?pt=Motors_Car_Truck_Parts_Accessories&hash=item258443cfd6&vxp=mtr
Old Oct 27, 2013 | 07:33 AM
i have a 3:73 rear end should i change to 3:96 or 4:10 also or am i ok with 3:73?and would upgrading my axles make any difference?im new to all of this so all help is thanked
Old Oct 27, 2013 | 10:33 AM
BIGCAT7274's Avatar
Originally Posted by Bow Tie Power
Personally, I'd build the motor. Leave superchargers to the pussies with the Crustangs.
lmao. the quickest pass by any ltx was just done with a f1x supercharger.
Old Oct 27, 2013 | 10:34 AM
BIGCAT7274's Avatar
Turbo it.
Twin x275 88s.
Do it.
you cant run 2 in x275. hell 2 76's would make stupid power let alone 2 88's.
Old Oct 27, 2013 | 05:08 PM
im not running turbos if i wanted a turbo car id go buy a grand national, i just want a fast street car not a track car lol
Old Oct 28, 2013 | 06:35 PM
BIGCAT7274's Avatar
If you can find a vortech kit with a t trim you can make some good power with it. Procharger d1 will also make good numbers.
Old Oct 29, 2013 | 07:40 AM
i got a plan now after talking to a few performance shops and finally getting a lil help from one of my boys who have track cars after them seeing my frustration about my car and it being end of race season.
im going with either dart 215cc or afr 227cc heads,bulletproof 4l60e instead of 700r4 i have now,grand national rear end built with 4:10 gear,posi,and stronger upgraded axles,150 shot nitrous kit,lt4 intake and if i find a charger would be nice to add to this setup lol
Old Dec 2, 2013 | 10:12 PM
SC383's Avatar
I'm thinking of parting with my vortech V1 T for a turbo setup.
Old Dec 3, 2013 | 10:22 AM
nomoneyz's Avatar
LT4 intake is internally the same as the LT1.
Got it. Forgot you had a gbody.
Old Dec 3, 2013 | 10:48 AM
97Z28SS's Avatar
^^^^^^^ The OP has a Gbody (Monte Carlo, GN, Cutless) so the GN rear is a direct boltin for the OP's car.
Old Dec 3, 2013 | 10:50 AM
sweetbmxrider's Avatar
i have a 1985 olds cutlass with a 355 fi lt1 from a 95 camaro in it and wanna go super or procharger and i can find is ls items or turbos can i get a lil help ty
Originally Posted by nomoneyz
Someone correct me if I'm wrong but, that gn rear end is never going to work without tons of fab. Not worth it when there are many bolt in options. LT4 intake is internally the same as the LT1.
Corrected, you're wrong
Old Dec 3, 2013 | 01:37 PM
  #32
bufmatmuslepants's Avatar
Bulletproof 4l60e? Upgrade to an lt4 intake? AFR227s on a 10:1 355? Sounds like your friends know their stuff.
Old Dec 4, 2013 | 09:25 AM
  #33
Valkyn's Avatar
Any info on this?
Old Dec 4, 2013 | 05:35 PM
  #34
BIGCAT7274's Avatar
Originally Posted by Valkyn
Any info on this?
http://ltxtech.com/forums/showthread...944-LTX-Record
Old Dec 5, 2013 | 10:56 AM
  #35
Jeff Thompson's Avatar
here you go http://www.tickperformance.com/proch...t1-camaro-t-a/
