starting a new lt1 build need advice
Old Dec 5, 2013 | 09:28 AM
rjmarazzi's Avatar
Default starting a new lt1 build need advice
Hi guys
I am wanting to start a 383 lt1 build. I was going to do a prochager build but they are a little pricey so I'm am going n/a. I have a set of conventional sbc heads from a project that is now sold. What dose it take to make the 23 degree heads work on the lt. If it is not worth it I may just sell them and get something else. The heads are jegs brand 2.10 intake and 1.60 ext with unported 220 cc runners. I was just looking for some input.
Old Dec 5, 2013 | 10:10 AM
noice's Avatar
Look at the difference in the water pump gaskets and you'll see it is not a viable option for most to convert SBC heads to reverse cooling LT1 heads.
Attached Thumbnails starting a new lt1 build need advice-dsc00647.jpg   starting a new lt1 build need advice-41afoufn42l._sy300_.jpg
Old Dec 5, 2013 | 10:20 AM
RamAir95TA's Avatar
What kind of cash you got to spend?
Old Dec 5, 2013 | 11:16 AM
rjmarazzi's Avatar
I would like to stay around 6k and by the looks of it 1/3 of it is going to be on a new set of heads. We all know that what ever the bubget is add 2k to by the time your done. Those heads will most likley be for sale!
Old Dec 5, 2013 | 11:46 AM
rjmarazzi's Avatar
I would like to use the 2k for the rear suspension on the car and a good converter.
Old Dec 5, 2013 | 12:02 PM
hokeplaya05's Avatar
if i were you i would look for a set of used stock aluminum lt1 heads (classifieds, craigslist etc.). i reused the stock aluminum heads that came off the lt1 that came in my car and had a machine shop go through them and port them as well as install upgraded springs
Old Dec 5, 2013 | 12:08 PM
bufmatmuslepants's Avatar
I think competition performance or someone was doing it for $400, but the you'd need a super Vic and an elbow and a cowl hood and a ls1 tb and rails and blah blah
Old Dec 5, 2013 | 12:09 PM
No the saying is multiply the budget x 2 and add 1.5 years.
Old Dec 5, 2013 | 12:27 PM
rjmarazzi's Avatar
That is very true.LMAO
