Looks like my optispark is dead again!!!
Old May 7, 2004 | 06:54 AM
96SCTA's Avatar
Default Looks like my optispark is dead again!!!
Well this makes the 3rd one in under a year. And im done with them. Any of you guys running the lcc. How much did it cost tottal. And where the hell am i going to put all those coils. ?????? How long does it take to install.
Old May 7, 2004 | 07:18 AM
SuperStud's Avatar
check this out: http://www.delteq.com/opti_stage1.htm
Old May 7, 2004 | 08:38 PM
00Z-28-LT1's Avatar
http://www.bailey-eng.com/LTCC.html or u can also stay opti and do this http://www.dynotech-eng.com/dynaspark.htm and the delteq is cool as well.......its ur money....
Old May 7, 2004 | 09:40 PM
Camaroholic's Avatar
What is failing on your optispark?
I know a couple of guys who have had trouble with theirs. Their problem was traced to the cam dowel pin protruding from the cam just an ooch too far. It was causing warpage and eventual opti failure. You MUST verify that your cam dowel is at the correct distance from the cam face (I believe it's .6", but it's been a while...).
I'm running a Dynaspark in my '94Z. I like it - works well so far. But the LTCC or that other one would be good alternatives too.
Of course, the Dynaspark cost more than the motor I attached it to.
