Nitrous questions
I recommend a window switch and the Zex wet kit. thats what i have and it says right in the instructions no ignition retard on the 100 shot. it has a TPS controlled switch to engage the system and that is helped with a window switch i set mine to 3500rpm in second gear.
http://www.edelbrock.com/automotive_...ech_tips.shtml
Been reading about that and most of them recommends retard timing.
2: He has a cam, So you should assume that he has a tune for that; this means that if the tune is done by someone competent, then the timing has been adjusted for MBT and would be too far advanced to run a 100 shot on it without taking timing out.
The (no retard for up to 100 shot) is for stock timing tables on an otherwise stock engine.
