cc306 cam with 0 supporting mods :o
It would have been sooner than that it the lobes wasn't so lazy on the CC306
When it goes he will be rebuilding another engine...
Max lift on stock lt1 springs is somewhere around .480? cc306 with 1.5 rockers (if stock) is .510/.540. Worse if he is running 1.6 obviously.
you do the math (just wanted to say that)
It may last another couple hundred miles, or a couple thousand, either way its not going to be anywhere near what a oem mass produced engine will.
Coil bind is good for everything. Id guess his lifters are making up the difference.
