changing cams.
I would double check with Lloyd before making any changes, since he will know all the specifics on the heads you have and will be the most informed to suggest the proper cam.
You didn't mention the heads. How big are your intake ports? How big are your headers? Your running full exhaust?
It will need shifted at 7000-7100. No big deal. Your converter is too tight for that much cam. Mine liked 4400. Your 60's are terrible. There is well over a tenth available right there. At least two.
I'm pulling more weight down the track with just a 228 dur cam in a 350 and have been in the 6.90's, but (to Ed's points), I'm not handicapping it with exhaust, converter, gearing, shift points, tune,...etc. that aren't up to the task.
