Thoughts on my LT1 Shortcomings
"Cars are actually quickest when run near max injector duty cycle, the 85% rule is wrong. IF he needed injectors 30lbs would be MORE than enough."
Ask the LT1 Stock Eliminator guys. I know of none (A good friend has one of the fastest on the planet) NHRA Stock Eliminator LT1 cars runing bigger than 30 lbs, and making way more than any "cam only" car, or "cam & head" cars around here. Or 95% of the built engines for that matter.
Higher fuel pressure atomizes the fuel better, making more power than larger injectors. I have proved this multiple times on my dyno. Stock 24lb Injectors at 60 psi are 28 lbs. Lots of 400 rwhp LS1s running around with stock 28 lb injectors. I'm at 600 hp with 36lb. plenty of injector.
The charts you are referencing are SALES TOOLS not legitimate information charts.
People think running an injector at 100%DC will hurt it but in the course of a say 12 second 1/4 mile run the injector would only hit peak at the top of each gear, spending maybe a second or so at a time near 100%. If that were damaging then how on earth can they survive flow testing?
Plus there is a nice cooling flow of fuel going through.
Maybe YEARS ago when injector technology was newer running injectors at 100% damaged them but it is not the case with LT1 and newer stuff.
Those 12" header extensions aren't likely doing your hp numbers any good. They will only help your O2 readings at idle, part throttle and lower RPM. WOT above 2500 or so, they won't help.
Open headers makes your power numbers look even worse. Hope you find your problem. Sure can be frustrating.
The pistons probably weighed 600grams or so, that sound ballpark? Stock is about 530 if memory serves.
Stock crank is great money spent on a forged 3.48 stroke crank is a pretty poor choice unless the crank has some other advantage like lighter weight and a stocker would have saved even more money by being easier to balance.
If the 320rwhp was near accurate any decent catback isn't going to cost you much power, the wide LSA of that cam wont make it terribly exhaust sensitive.
Get the tranny fixed and take it to the track, if it runs say 106mph you will know the dyno test was in the ballpark and it it runs say 113 you will have an indication the tranny was slipping hurting the dyno number a lot.
ET can vary dramatically with the launch but MPH while it will vary a little is far more consistent with a good or bad launch.
Doing things "inexpensively" often costs a whole lot more in the end. A well done 355 or rather 357 with the .040 bore should need a rollbar in good weather NA in a street car.
Far as the nitrous how much do you plan to spray? Just enough to get into the 11s or are you thinking 200hp worth? The more you spray the harder it is to keep balanced when spraying this intake from the front, more than a few LT1s have fragged #1 or #2 when sprayed hard from the front because the fuel can't make the downward turn to those cylinders as well as the nitrous can and BOOM. A LOT of guys have hit LT1s with 150 or so for a long time successfully if tuned well.
I would look at a Mallory 685 box for spark based rev limit, on demand timing retard, and window switch functions.
None of the tracks tech around here for TnT sessions so you don't really have to worry about a roll bar. I've seen people running 11s and 10s with no helmet on many times.
I agree with quik95, take it to the track to see how botched it is. It's really easy to screw up these heads, I bought mine super cheap which are home ported, and though the runners and valves are huge, they may be only worth the springs (which is what I paid). Size doesn't matter, it's the motion of the ocean, at least that's what my wife tells me, even though it takes a long time to get to England in a row boat.
