Miss only under load
02's do nothing at full throttle.
If you have a decent scan tool you can see which cylinder(s) have a problem.
To eliminate an injector just swap one from a problem cylinder with one from a good cylinder to see if the problem moves. If not, of course, they are OK.
Ohm the plug wire on the problem cylinder(s), should be high resistance (like 10k), but not open.
Good luck.
