what gears and stall?
Old Jan 21, 2014 | 12:16 PM
chet1185's Avatar
Default what gears and stall?
I have a 95 TA, A4 2.73. Are these the right gears for mine?
http://www.summitracing.com/parts/sum-741012
Also, what size stall? No cam yet
Old Jan 21, 2014 | 12:33 PM
pillarpod's Avatar
depends, you have a 2 Series or 3 in your rear?
Old Jan 21, 2014 | 12:47 PM
chet1185's Avatar
Wouldn't it be a 2series with the gears it has now?
Old Jan 21, 2014 | 01:20 PM
93M6Formula's Avatar
Correct.
Old Jan 21, 2014 | 01:29 PM
95mysticta's Avatar
Yank SS3600 Stall
Find a cheap 6spd 3.42 rear or buy and install 3.73s into your current rear.
Night and day difference in how your car will run and feel.
Old Jan 21, 2014 | 03:24 PM
96lt1m6's Avatar
My suggestion is,
3.73S
3600 stall
Drag radials
TUNE............
Old Jan 21, 2014 | 03:52 PM
chevy94c's Avatar
3200+ yank or vigilante
3.42 or 3.73
DR
tune
Old Jan 22, 2014 | 01:15 PM
96TransAmboosted's Avatar
I started with 3.73 and they were ok if your old and care about gas prices. But if you want to have fun and destroy cars off the line then 4.11 richmond race gears, i would weld the axle tubes and get a good girdle for the little 7.625 housing or you will break gears sooner or later. Get your tranny flushed and replaced with fully syn fluid you will thank me later. Biggest trans cooler you can find and mount right to the condencer this will save your tranny from the stall you put in it. Once you do those then a 3600-4200 stall will be perfect.
Pick a goal for your car then decide what parts you might need, are you going to build motor down the road, street only, track only, SS, power goal, et goal etc then it will make it easier to help you.
I run a 4.11 , billet triple disk 3600 converter and drive it everyday long and short trips with no issues ever, well i do have an issue slowing down for Mustangs but other than that its great
Old Jan 22, 2014 | 01:26 PM
SwampWS6's Avatar
What he said X2! I have a 3700 Stall TC for sale brand new too!!!!!
