Looking for This part
Old Jan 23, 2014 | 04:29 PM
BALLSS's Avatar
you can buy bulkhead rubber gromets in various sizes and put those on BEFORE you run your wires...or slit it and install if they are already run.
most hardware stores have them in the nut/bolt section
Old Jan 23, 2014 | 07:06 PM
stevo9389's Avatar
You live in Pinellas Park so the LKQ off of Ulmerton or the big one in Tampa should have something as I was picking interior pieces off a couple a few weeks ago. I have found several from there with tops still attached. Even if they are broken or faded you can clean them up with minimal effort, paint them if necessary and add a small hinge to the top so it stays on. It sounds really ghetto but I had received a few compliments after going mine like that years ago.
Old Jan 23, 2014 | 07:48 PM
96TransAmboosted's Avatar
I look everytime I go there and found a few but not in very good shape. Seems like I need to start grabbing every one I see from now on, I thought I could just buy a new one.
Old Jan 23, 2014 | 08:45 PM
1993yellowbird's Avatar
I am looking for one of these parts as well. I have ordered from two places and they have both come back as not available. Mine is broken and is causing me power issues. If there a different solution that anyone can reccomend?
Old Jan 23, 2014 | 09:07 PM
shbox's Avatar
Any kind of decent, insulated terminal post of the same size should work. It's just a junction point.
Old Jan 23, 2014 | 09:12 PM
Is there a part number you could post to reccommend? I know how to replace parts but not necessarily fabricate things. I know this is simple but I dont want to experiment on the car, I just want to bolt in and go. I'b be happy with a used example with the studs the wires mount to intact and tight, unlike mine.
Old Jan 23, 2014 | 09:20 PM
shbox's Avatar
I didn't have any particular one in mind, but places like Summit, Jegs, etc and parts houses should have many choices.
Old Jan 23, 2014 | 09:49 PM
Fastbird93's Avatar
I thought I saw somewhere recently where someone was making reproduction versions of these. It got my attention because the top is broken off mine (go figure) and I immediately thought, hey, replacement! I'll see if I can't pull up where I saw it.
Old Jan 23, 2014 | 09:56 PM
The link on the previous page to hawks third gen references a reproduction part with a better lid is,was,will be available. I'm planning on contacting them tomorrow, see what I find out.
Old Jan 24, 2014 | 09:34 AM
moehorsepower's Avatar
They sell bulkhead grommets for wire feed thrus, but in a pinch, I use the appropriate size vacum hose and just slit it down the middle.
Old Jan 24, 2014 | 09:43 AM
Hawks said there going to be coming out soon but not just yet. No price either
Old Jan 25, 2014 | 06:23 AM
  #32
I saw one that the owner replaced the whole terminal with what looked like something for a stereo setup for large gauge wires,looked trick with a lexan cover, Dont know if he fabricated it or that is the way it was made. Like Shbox says, its only a junction point.
Old Jan 25, 2014 | 09:10 AM
  #33
This is what I used, it's a fuse holder I'm using a 250a fuse for a just incase since everything is in the wheel well now. Plus mine has a weather proof cover so I don't worry about water. Ebay sells them for 15 bucks.
Old Mar 13, 2014 | 02:53 PM
  #34
The reproduction power junctions are now available on hawks third gen if anyone still needs one.
