Exhaust idea
I tried to draw a picture to explain how it is setup:
I don't really want to spend all the money on a brand new catback and I can't find much used around me. My idea is to buy these two parts from dynomax #45593 and then #42273. Would these two premodern parts connect my header y-pipe all the way to the muffler?
Also why run 3 in pipe then back to 2.75? Keep all the pipe the same size
I'm trying to get 3" all the way back now in full piece pipes like the catbacks are instead of a bunch of autozone pipes clamped together.
I will never pay an exhaust shop $$ to make anything for me ever again except to flare ends if I need it or to buy straight section of pipe.
You can buy mandrel bends online and make your own.
I found a flux core Lincoln welder on craigslist for $125 or so a year back. Has worked flawlessly for making exhaust on a DD cars lol.
What's worse is those damn cheap U clamps...I despise those and anyone that uses them!
See here: https://ls1tech.com/forums/17799355-post25.html
I wouldnt buy any more actual exhaust parts until you can afford a real catback. Most of the time a used catback will require additional work if someone has already welded the tips on or cut it in half to get it off the car.
I have had those on my car for 19 years.
They can be had dead cheap,look around
