built lt1 oil pump choice?
I talk to a shop once and wider bearing clearances and HV pumps brought up. The shop only recommended running something like that with engines that see prolonged hard rpm usages. Such as but not limited to boat engines. Ill be honest it was 10 years ago and forgot the reasoning. I never did do business with them but I remember it being brought up.
My experience: 12 years of a Canton pan and Melling HV pump and no problems, knock on wood. Hot idle around 35-40 psi, 6100rpm 65 or 70 psi. CrUising around 55-60 or so. I've had the valve covers off with the car running and sure some oil splashed out but not more then expected. Ido have an oil fed supercharger in the system that might affect my results.
This is for a weekend toy that sees the 1/4 mile once in a while.
9-Second Club
Any bodies oil pressure that changes 30+ psi between idle & WOT with a high volume pump is leaking oil internally somewhere. Rod, main or cam bearings, or lifter bores. No way around that one.
I quit drag racing due to travel. & time away from our shop during the eighties. I could race at the local dirt track. (Ten minute drive) for as much as I was traveling to drag race. Anyway, I found no advantage to a HV pump in those either. Just more wear. We ran 35 & 50 lap races on the local 5/8th mile track. Dry sumps weren't legal for a few years. I had no bearing problems with the standard pump. That large clearance/thicker oil film/HV pump thinking around knowelagble builders went away well over ten years ago.
Man-Crush Warning
http://m.summitracing.com/parts/mor-22101
Would this be alright for a pump?
And which pan would you guys recommend?
http://www.summitracing.com/parts/mo...make/chevrolet
Or this
Or this
9-Second Club
Or this
Or this
OP -
Melling produces two different sets of pump gears; one set is about an inch (for the "standard" pumps), and a second set of taller/deeper gears that measure about 1.3 inches (for the "High Volume" pumps).
I've physically had two different Melling pumps in my hands, and the High Volume's oil pump body and oil pump gears are indeed different / longer than the standard pump.
The installed pressure relief spring determines the pressure (and Melling offers different springs for different oil pressures), however, the pumps with longer gears move a greater volume of oil per revolution of the pump, hence the "HV" callout.
I hope this helps clarify some of the issues being discussed here.
#33
Haha alright thanks again for the advice. Which pan would be better suited out of the two that I put up the links for?
#34
9-Second Club
The #20185, it is 7.5" deep. Other one is too deep. You would be banging it of the ground. When landing from standing it up on the bumper, you don't want to crush the pan. LOL Really, 7.5" is all you need or want. Make sure you order the correct part number pick up for the pump too.
#35
#36
![Icon Neutral](https://ls1tech.com/forums/images/smilies2/icon_neutral.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#37
This should be all together in a few weeks
Just need yo get the stuff for the 24x conversion. And the peripherals. I would like to have the engine broke in on a test stand. Is this possible with a fuel injected engine/ what is needed? Thanks
#39
What do you expect to break in? Cam and lifters need no break in unless you went flat tappet which leaves rings and bores but those are better broken in under load which is impossible on a test stand.
Running it on a test stand would be a great way to glaze the bores before ever breaking it in.
