misfire or hitting rev limiter?
Old 05-23-2004, 11:44 AM
DukesI3's Avatar
i have the EXACT same problem, i dont have a new tc. its started to happn less and less but it did it every single time i floored it about a month ago..??
Old 05-23-2004, 01:07 PM
ram air camaro's Avatar
so far it looks like the problem has been fixed on the 1-2 shift. i had bryan at pcm program my pcm for the torque converter because he said that some of the obd-1 car's will do that with a high stall, so far so good
i'm going to the track friday the 28th so that will be the real test.
Old 05-23-2004, 01:12 PM
(diet Coke) It Was The Pcm Not Reading The Torque Converter.
Old 05-23-2004, 02:48 PM
DietCoke's Avatar
Which is exactly what I said. Throw on some slicks and you'll have the same problem.
Old 05-24-2004, 03:49 PM
what do you mean by throwin in some slicks ad i'll have the same problem, dam cause i just bought some, you mean even after programing it will still do it ?
Quick Reply: misfire or hitting rev limiter?
