how will it run? with cam? please
The CC305 is an old SBC carryover cam with lazy lobes that like previously stated is an ok boost cam at best and an underwhelming n/a cam most of the time.
A high quality converter (Yank or Vig) with a stall speed in the 3400-3600 range would be a good thing.
If you're going to dig into it again I'd do a set of ported heads along with more cam. Of at least get the heads shaved for a bit more compression.
heads are shaved but got a 0.049 head gasket. Not optimal. . But I'm learning as I go
