24X Pros & Cons
Old Mar 6, 2014 | 01:08 PM
cardo0's Avatar
So i need to ask what is the rpm limit of my opti with OBD I? Just kinda curious even though my car barely gets to 6k rpm now.
Is it the PCM? or is it the opti-spark dist?
Is 7k rpm just a best guess or is there some dyno test data to support the actual limit.
I expect to need to now this limit for the future.
cardo
Old Mar 6, 2014 | 03:12 PM
96silverram's Avatar
I like the idea of HP tuners programming on the fly
Old Mar 6, 2014 | 03:50 PM
smitty2919's Avatar
cardo
From what I understand, the opti will start to "break up" at higher RPM's. Meaning it does not accurately read during higher RPM.
Old Mar 6, 2014 | 06:11 PM
BOLO's Avatar
cardo
I believe the Obd1 pcm is limited to 7100-7200 rpm. The optispark's rotor does not like 7000+ rpms, as well as getting wet from undercarriage carwash or leaking water pump.
