Least restrictive LT1 induction?
My old 190cc setup cranked like 227psi and was 11.2 compression. Current setup cranks even higher.
Really though I think the CAI is the culprit here, if the HP had gone wonky instead of flatline I would look at valve float. If it had just been soft from the start I would be looking at compression and some other things.
Compression test/press for your build would be good for u to know rather than rely on hearsay or someones else's guess. It only takes 'bout and hour to do.
cardo
cardo
cardo
I'm not a NA solid roller, but my cam is a 244/254 .574 114 LSA and the blower really needed a lot of air to see some gains. I ended up doing a custom sheet metal intake, and was very happy with the results.
I'm guessing you wanted to stay away from the sheet metal intake because of the cost. If you know anyone who fabricates, it may not be as bad as you think. I would never drop the coin that some of the ones go for online $1k+. I'm not saying mine was cheap, but it wasn't that bad either.
I had a Moroso (or Honker) CAI and a K&N CAI and I wanted to determine which one is better flowing. I tried both and monitored the pressure drop at the MAP sensor using datamaster and determined that the K&N has about 2KPA lesser drop compared to the Moroso at WOT. I would say that the much larger filter on the K&N CAI accounted for this. So IMO, the K&N flowed better. Is it worth ditching a Moroso and getting a K&N, no.
I then did a similar test with out a CAI installed without a CAI installed to see if the MAF had any restriction. So testing with the MAF on and then off, no change. The MAF poses no obvious restriction.
Same test with the elbow with no MAF or CAI installed. Big difference in pressure drop with the elbow pulled. SAo IMO, the 90 degree elbow poses a very significant restriction in the LT1 induction while the other components, not so much. I would guess that the flowing air in the elbow just gets "slowed" as it passes through hence the reason the LS1 straight should induction design works so much better.
I have an old thread somewhere speaking to these findings in much greater detail if your interested.
Here was my solution:
I have no data to say whether the new intake is an improvement or not. I just dl DataMaster and need to pick up a cable to be able to data log. I also have not gone WOT just in case it does flow that much better, I do not want to create a lean condition. I have plans to dyno tune the car soon though. That is a 4" to 3.5" coupler from TB to MAF, then the MAF, then 3.5" to 3.5" coupler to 3.5" exhaust pipe. MINIMAL hood bracing notching was required and a little flattening of at the top radius of the pipe...This fits under a stock 95 hood as well. It's the first prototype so it's not the prettiest but it seems to function lol.
Pointless semantics is posting a blower motor to offer advice to a NA motor question.
Yes, there are several lurkers here that have no helpful intentions.
I just consider them as parasitic drag to enthusiasm for high performance. Debating with them is wasted effort. But I do enjoy telling them that.
cardo
