Valvetrain mod questions
Old May 14, 2004 | 03:37 PM
smokin t/a 600's Avatar
Default Valvetrain mod questions
Hey i need to know what length pushrods to get with a stock cam, I am getting crane arms 1.6 RR, So which length pushrods should I get Ive searched the forums and couldn't find anything similar sorry if this is a repost.
Old May 14, 2004 | 04:12 PM
solid95z's Avatar
7.200"
If you mill your heads, change the deck height on your block, and depending on what cam you get will determine what pushrod length you will need. But with a stock cam just get 7.200"
Old May 14, 2004 | 10:39 PM
Gangly's Avatar
Stock pushrods are fine. even with an aggressive cam stock pushrods are fine. LT1 rocker arms arent mounted directly to the head and so they can rise up or down on the rocker arm stud to adjust the lash/height that they are set at. pushrod length isnt really a huge issue unless you are going with a HUGE cam/drastically milled heads, or something other than hydraulic roller on these motors. ARE has a longer stud that is 1.89" length for a lil extra clearance if you are running into problems with your rockers sitting too high and not getting the poly locks down in the rocker arm trunion(i believe thats what its called, havent checked in a while) enough.
