what kind of power do you think my 383 LT1 will make?
i would like if all of you can give me advice on what i should do or what i should change.. and what kind of power it will make ....
what i got...
:383 LT4 block
:Forged 4340 Eagle Crank
:Forged H Beam Rods
:Forged JE Custom pistons .30 over, Flat Top
:MSD 6AL with 8mm Wires
:1.6 RR
:CC 306
:Stage 2 LT1 Heads, 3 Valve angle job,milled, Flow @ 260 at .600 lift
:High Volume Oil Pump
:Stock LT1 Intake Match ported
:30lb. Injectors
:58mm TB
:SLP Mid-Lengh Headers 1 5/8
:3in. Borla Exhaust
:Stock Water Pump
:A/C Delete Pulley
:Stock Fuel Pump, Would like a 255 fuel pump
:Custom Tuning
any input would be great..
car weight is 3400 and has 3.73 , let me know
what i got...
:383 LT4 block
:Forged H Beam Rods
:1.6 RR
:CC 306
:30lb. Injectors
:58mm TB
:3in. Borla Exhaust
:Stock Water Pump
:A/C Delete Pulley
:Custom Tuning
i would go long tube headers. also the 58mm tb is over kill i would go with speed and marine 54mm. they make the best tb. i got pretty much the same setup but im gettin afr 195's and a custom cam from comp cam. im lookin for like 500 fwhp maybe little more. you wanna flow as much air in and out less restriction on both ends produces more power!
I've got a 58mm on my 4.3L L99 motor.
And zero MAP drop at WOT.
Throttle tip-in is a bit interesting tho. If I slam my foot to the floor, velocity is down so it doesn't take off right away. But if I ease in to it, air velocity is higher, and it picks up better.
I had it on my old heads/cam motor (before the boom). Didn't feel like taking it off my intake when I swapped motors.
I say go 58mm. You'll be kicking yourself (or you may end up selling the 54 and buying a 58)...
what i got...
:383 LT4 block
:Forged H Beam Rods
:1.6 RR
:CC 306
:30lb. Injectors
:58mm TB
:3in. Borla Exhaust
:Stock Water Pump
:A/C Delete Pulley
:Custom Tuning
what i got...
:383 LT4 block
:Forged H Beam Rods
:1.6 RR
:CC 306
:30lb. Injectors
:58mm TB
:3in. Borla Exhaust
:Stock Water Pump
:A/C Delete Pulley
:Custom Tuning
http://www.geocities.com/phillipbridgesracing
