Lurking p0507 code please help
Old Mar 30, 2014 | 12:55 PM
BayAreaMuscle's Avatar
Default Lurking p0507 code please help
I'm chasing down this trouble code and I can't figure it out. My idle is around 800rpm warm. Only weird thing I've noticed is my rpms bounce 100rpm when I hit a bump but that's it. Car runs great otherwise, I'm really stuck here and in need of some serious help
Old Mar 30, 2014 | 04:01 PM
shbox's Avatar
Check vacuum hoses.
Old Mar 30, 2014 | 06:22 PM
Just checked all of them and swapped a couple of vAcuum elbows as well as the pcv hoses. Do you know if the passenger side vent hose is supposed to have vacuum ? Mine doesn't have any, no change in idle when unplugged either.
Also any clue as to what would cause my rpms to bounce on bumpy roads ?
Old Mar 30, 2014 | 06:24 PM
Also do you have a diagram the vacuum hoses ? Just want to make sure I checked them all
Old Mar 30, 2014 | 09:36 PM
shbox's Avatar
Which hose do you mean? The one going into the valve cover? There won't be any vacuum from the TB side at idle.
There should be a vacuum hose diagram on your radiator cover.
Old Mar 30, 2014 | 09:57 PM
Yea the passenger side valve cover. Ok just making sure
Old Mar 31, 2014 | 08:46 AM
96TransAmboosted's Avatar
Have you run the car to see where the iac is at? Or what your map reading is
Old Apr 1, 2014 | 12:04 AM
No I haven't yet mostly because I'm not really sure what I should be looking for. Any tips on what to look for? Code hasn't popped up again so far but my idle still bounces 25 rpm once in a while
Old Apr 1, 2014 | 06:38 PM
Iac count should be 54 or so on a cold start it will be higher then come down.
Old Apr 1, 2014 | 09:54 PM
Ill check that asap. Code came back today, any thoughts on my tps maybe reading the throttls blades position wrong ? Im gonna drop it off at the mechanic this weekend if i cant figure it out.
