oil/coolant problem
Old Apr 6, 2014 | 06:19 PM
BallerCamaro21's Avatar
Default oil/coolant problem
What would cause oil/coolant mix in the intake valley?
Old Apr 6, 2014 | 08:06 PM
agchoset's Avatar
Since the LT1 uses a dry intake (no coolant crossover), a bad head gasket would be a concern. Cracked/warped head or block could also cause coolant to appear in the oil.
Old Apr 10, 2014 | 05:22 PM
RogueLT1's Avatar
I would lean towards the head gaskets. what does your oil look like on your dipstick / under your fill cap? have you overheated the car or wrecked it?
