Anyone interested in not having to remove the water pump in order to change the opti
Thank you. I am waiting to hear back from a shop that will broach me an extended shaft coupling. After I get that I will install it on an f-body and get good video to show if its viable or not.
Quick ? when installed with the spacer how much room will there be on the middle bolt on the left hand side of the water pump. How close will the bolt be to the back of the power steering pulley. I don't like the idea of removing my power steering pump to replace the water pump if there no room to get the bolt out. Other then that sound good to me
The power steering pump is two 10mm bolts accessed through the pulley with the belt off, very very simple and the system remains closed.
I'm interested in this.
