ls7 lifter preload
All my life I have been setting Chevy hydraulics at the top, you know just where the push rod tightens and then another 1/4 or 1/2 turn. But I always do it with the engine running. Been preaching this for over 50 years.
Word is the newer Chevy's like to be set the other way. My 95 LT1 is set about 1/4 turn from the top, and I can get 7,200 RPM out of it with a Lunati Voodoo cam, LS7 lifters and Manley springs. But I want those of you who are interested to google "travel limited lifters in '87 up chev oem roller blocks." and variations of that and see what you think. There is more than one discussion on it. I'm not so sure I believe it and am afraid to try
The new way is to set them at the bottom, like .020 or even .010 from the bottom and.... well just google and see.Sorry to throw a wrench in this thread. Feel free to move it.
Al 03 Mustang. Ford POS makes it easy, no valve adjustment
Here's how i remember.
E.very O.liver I.s C.ool
Which means= E.xhaust O.pening I.ntake C.losing
When exhaust starts to open,adjust intake
When in take is closing,adjust exhaust
One full turn (from zero lash) is approximately .040 of lifter preload.
This works on any pair of valves for the cylinder your working on. Or any 4 stroke for that matter.
Hope this helps
Sure soon as u explain why a lifter cant bleed down with the engine on?
The lifters will bleed down some when the engine is off
And yes i have built my own engines and they all ran. BTW i thought i read u trashed your new cam recently? True?
Are u saying then that your vlv train does not wear at all? Then why not just use your "experience" to set your preload even less??
http://www.tuning.mbs.id.au/Engine/hyd_lifter.htm
Throw it in the LS and the preload is 070"-.090"
Throw it in a Harley and the preload is .100"-.120"
For the same lifter.
I need to take the calipers to my rollers and see how worn down they have become. I'm sure they were part of the culprit!
That's right, I fed the troll.
Now some lifters do have holes/passages that may become blocked if adj to "deep". U have to know what your lifter can use for max preload.
Thx for sharing Al.
One of the SA Design books and i can tell u need to read them all. Have fun.
Absolutely true. I guess it's because the solid lifters I was running bled down... Do you have any advice?
Find a new hobby. Try golfing. U'll get to play with little ***** all day - that should keep u happy.
Thanks
Also, what caused my cam and lifters problem? I am stumped. Could it to be because of lifter bleed down and aerated oil?
Why cant u tell why a hyd lifter cant bleed down with engine on.
U
Thx for sharing Al.
Al 86 IROC, BBC, Ford Toploader, 9"
