misfiring lt1
Old May 16, 2004 | 06:49 AM
GTNOTME's Avatar
Angry misfiring lt1
my car is a 94 camaro lt1 the engine has been rebuilt splayed mains, h-beam rods, steel crank, je pistons, cnc ported heads, comp cam, roller rockers, 30 pound injectors, larger throtle body, msd ignition box, malory coil, 9psi intercooled procharger, ed wright programing, the seens to run rich but ok cold but as it gets warm the low coolant light comes on the car seems to breakup and be erratic at cruise speeds the low coolant light has been acting up ever sence the motor was reinstalled bad senser? local techs are baffled no idiot light, o2s are working, temp sensors are working on the scan tool ,could it be the mass air? HELP!!! know of any good tuners in west michigan befor i sell this thing
Old May 16, 2004 | 04:45 PM
ram air camaro's Avatar
www.pcmforless.com
that's a good place to start.
are you running in stock tuning?
Old May 16, 2004 | 05:41 PM
GTNOTME's Avatar
the computer has been sent to fastchip 2 times to address the rich condition at lower rpm and to set the tune for all the mods, the surging at lower rpm as soon as the car heats up is unrelated to the tune, it developed after the car was running good, any ideas
Old May 16, 2004 | 08:33 PM
OneMeanZ's Avatar
PCMforless is good, but the only way to get a good tune is to get it dynoed tuned..
