Racetronix injector question
Old Apr 22, 2014 | 09:07 PM
ale76051's Avatar
Default Racetronix injector question
I'm looking to get a set of 32lb racetronix injectors, 135-INJL32-8. But my question is, are they rated at 32lbs at 43.5 or 58 psi?? I can't find the test pressure online. Thanks
Old Apr 22, 2014 | 10:55 PM
warriorcustoms's Avatar
Give Nitrous Outlet a call @ 866-648-7637 theyre dealers & the customer service is 2nd to None!!!
Old Apr 23, 2014 | 02:10 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
All of our injectors are rated at the industry standard of 43.5PSI @ 20C. Injector flow rates are based on testing with n-Heptane test solvent (0.6855 g/ml). U.S. EPA emission test gasoline 40CFR86.113 (0.735g/ml) flows in most common injector designs at about a 3 to 4% higher rate than n-Heptane. A ratio of 1.035:1 can be used when converting the flow specifications.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Apr 23, 2014 | 05:42 PM
ale76051's Avatar
Awesome, thanks
