ignition decision
Old Apr 24, 2014 | 09:43 PM
cybergreenZ's Avatar
Default ignition decision
ok so im new to to the site and have a problem I need help with. So I have a fresh built lt4 383 that's gonna be equipped with forced induction. Today as I attempted to install the optispark I discovered the cam gear is that of the newer style instead of my 93. Question is which roué should I go to solve my problem. I don't want the timing set removed so should I try to convert to the newer optispark. Go with a dynaspark or 24x conversion. Whats everyones opinion. I do have a FAST xfi new 93 optispark and pretty much everything to finish the car so I want the best for the car its been a long time coming
Old Apr 25, 2014 | 07:11 AM
Mystery Bird's Avatar
I run the Dynaspark, cause it sounds like a super hero.
Old Apr 25, 2014 | 12:09 PM
So my hold up is I have everything to finish the car but because my engine builder put a cloyes hex adjust timing set for the newer optis im at a stand still. was just wondering which route I should go. Is anyone running a delteq setup
