True duals guys chime in please!
Old May 8, 2014 | 01:57 PM
z28andy's Avatar
Default True duals guys chime in please!
Hey guys this is only my 2nd post but I've been reading on here for some time now.
I know this topic has been beat to death, but my question is on pricing and labor.
Ive already ordered a set of pacesetter long tube headers and (2) 3" diameter-12" length dynomax bullet mufflers (I've heard them, I like them)
My question is, how much should I be looking at to complete my system? Should I order a jegs/summit 3" x pipe or have a muffler shop fabricate one for me? I also need the turn downs.
Thanks in advance for the input fellas.
Old May 8, 2014 | 03:33 PM
bad_408_vert's Avatar
andy
I just got true duals done on my ls1 car and I paid 250 for labor.
One thing I really recommend is getting both pipes placed on right side of driveshaft.
It really makes things easy to service trans if you need to.
Also use ball flanges between x pipe and bullet mufflers (also easy to unbolt if you change your mufflers in future).
The universal kits usually requires lot of fabrication (no personal experience but from what I read on here).
I really recommend using the narrow x pipe from summit. Part #643130
Turn down tips are easily made at a exhaust shop and probably cheaper to do than buy pre made.
Old May 8, 2014 | 06:48 PM
z28andy's Avatar
Hadn't even seen that x-pipe option, looks like a much better alternative. I roamed around town today and found a few muffler shops, most didn't have mandrel bending equipment... so now its either that wrinkle bent stuff, or welded, I'm in a pickle.
And actually I believe as long as I don't weld the collectors I can have the rest welded and just unbolt the entire piece (collectors-turn downs) to get the transmission out?
Old May 8, 2014 | 06:59 PM
DUDCOUPE's Avatar
My true dual dumps cost me around 400 i believe. Summit x pipe, summit header exentions, magnaflow bullet mufflers, summit dumps, 5 foot 3" pipe, and all band clamped together. Mine tucks really nice for a 3" setup
Old May 8, 2014 | 07:15 PM
z28andy's Avatar
got any pics of that setup?!
Whats the need for header extensions?
Old May 8, 2014 | 07:28 PM
z28andy's Avatar
This is exactly what I'm looking to do.
Old May 8, 2014 | 07:35 PM
DUDCOUPE's Avatar
Mine basically looks like that, x pipe isnt wide enough for our headers. That and there slip fit extensions
Old May 8, 2014 | 07:36 PM
DUDCOUPE's Avatar
All you need also is a grinder to cut pipe and a welder. I didnt have access to a lift when i did mine
Old May 8, 2014 | 07:41 PM
z28andy's Avatar
IM looking to have mine done by a shop, just wonderin how much this would cost in labor.
If i had a lift and the necessary tools to do it id do it myself also.
Old May 8, 2014 | 08:35 PM
DUDCOUPE's Avatar
With all parts i cant see more than 250 for them to charge. Should take about 2 hours
Old May 8, 2014 | 08:49 PM
95_TA_USMC's Avatar
True dual borla xr-1's sound amazing
