I have a problem with removing the front swaybar
My problem is with one of the bolts on the bushings. Three of the bolts looked like this (a normal bolt):
And the problem bolt look like this:
It had a nut on the bottom of it that I removed. The nut in the middle seems to be a 13 mm just like the nut I removed, but it must be rounded off a little because I can't get it to back out with my wrench. Is there a trick to removing this bolt that I'm not seeing? This is the only thing holding me up from completing this project and everything else has gone smoothly.
Thanks
