Who says...
Old May 22, 2014 | 08:49 PM
SS RRR's Avatar
Village Troll
Originally Posted by speed_demon24
Update?
1. Heads are away.
2. Got to get hoist to put engine on stand.
3. Your **** is a turd.
4. Eat me.
Originally Posted by reservoirdogs12
SS RRR, is that car color "mystic teal pearl"? I ran my VIN in one of those databases and it said that was my car color. It's strange, because when I first bought it I could see that bluish tint like yours has, but years later all I see is green. It still changes color a bit in different lights, but I feel like I'm going colorblind. Or maybe I wax it too often.
Same thing for me. In false light it still shows up, but natural light it's green these days. Paint is bad on this car anyway. Would like to get it repainted the same color at some point in time. IIRC the factory name for this color is Bright Teal Metallic. Here's a pic a few days after I bought it new:
Originally Posted by PA94Z
Whats the real plan? Or are you really doing a AI topend?
The only plan I have now is to fix it. Most likely going back to hydraulic.
Old May 22, 2014 | 11:35 PM
guppymech's Avatar
^^^SS RRR that sure looks purdy and a hardtop to boot!
Old May 23, 2014 | 05:16 AM
PA94Z's Avatar
What happened.. did your lifters take a **** and throw needle bearings everywhere? If you posted this already I missed it.
Old May 23, 2014 | 09:46 AM
SS RRR's Avatar
Village Troll
Thanks. I actually wanted t-tops, but after some talking to from a fellow car enthusiast as well as the problems I had with my 3rd gen t-tops leaking, as well as wanting to auto-x I opted for the hardtop.
Two lobes and rollers on the lifters are wiped. Metal is in the oil. As a precautionary action the engine is going to be torn down to inspect the bearings, cylinder walls and piston skirts.
Old May 23, 2014 | 10:01 AM
Shownomercy's Avatar
Man-Crush Warning
Damn race car stuff, gotta run a 3/4 cam next time.
Old May 23, 2014 | 10:19 AM
sweetbmxrider's Avatar
Originally Posted by SS RRR
Going to strip the unecessaries, go AI and race you for money.
A tax deductible donation for meeeeee?????
Old May 23, 2014 | 10:36 AM
Fast355's Avatar
Last LT1 F-car I pulled the engine out of, I pulled through the top with the transmission still attached to it. Just remove the EGR valve, fuel pressure regulator and crankshaft pulley first and out it comes right out.
Old May 23, 2014 | 11:23 AM
SS RRR's Avatar
Village Troll
I was running a half cam before. Going to go full ******' race cams this time around.
Depends on if you can pull more weight out of that jalopy. Probably would show up on the chassis.
Old May 23, 2014 | 11:38 AM
speed_demon24's Avatar
1. Heads are away.
4. Eat me.
Finally ditching those POS heads?
Old May 23, 2014 | 12:47 PM
SS RRR's Avatar
Village Troll
Don't you dare speak of my Lingenfelter heads that way.
Old May 23, 2014 | 02:18 PM
BALLSS's Avatar
Two lobes and rollers on the lifters are wiped. .
what lifters and cam did you have?
Old May 23, 2014 | 02:24 PM
  #32
Mystery Bird's Avatar
1. Heads are away.
4. Eat me.
That is redundant.
Old May 23, 2014 | 02:56 PM
  #33
SS RRR's Avatar
Village Troll
Originally Posted by Mystery Bird
That is redundant.
And true.
Old May 24, 2014 | 03:20 PM
  #34
97REaper's Avatar
That's the same thing I was thinking when I did it. Didn't even have to jack up the back of the car.
Old May 25, 2014 | 02:47 PM
  #35
BALLSS's Avatar
OP
can you answer the ?
lifters, cam....and "lash" procedure....
Old May 25, 2014 | 07:29 PM
  #36
SS RRR's Avatar
Village Troll
Are you wanting to diagnose my problem and tell me where I went wrong?
Old May 25, 2014 | 08:24 PM
  #37
PA94Z's Avatar
I am curious to about the lifter brand anyway.. I am sure they were pressure fed rollers, but there are many brands out there. Some good and others not so much. I am running bushed Isky EZX lifters to stay away from needle bearings in the case of failure.
Far as what went wrong.. likely the same as many other solid roller failures on the street - the lifters siezed up and took the cam with them. How often were you checking and adjusting lash?
The no maintenance hydraulic rollers are nice to not have to worry about. Easier on springs to. I can understand the switch.
Old May 26, 2014 | 07:44 AM
  #38
SS RRR's Avatar
Village Troll
I too am running the Isky Red Zone lifters with a Cam Motion cam. Pretty sure I bought them before the EZ roller became available. Don't remember that being an option. The rollers are not seized. Because there are two rollers and lobes damaged I have a hard time believing it was from the neglect of adjusting them properly since this engine has been together since 2007. I was OCD when it came to checking and adjusting lash.
Old May 26, 2014 | 09:31 AM
  #39
Man-Crush Warning
So will we get a straight answer on whats going back on??/
Old May 26, 2014 | 10:50 AM
  #40
SS RRR's Avatar
Village Troll
What's with this "we" business? You the appointed spokesperson?
At this point in time what I do know is my crappy LINGENFELTER PERFORMANCE ENGINEERING heads will be reused. I will be going back to hydraulic, but have no idea beyond that.
