Who says...
Old Mar 11, 2015 | 10:25 AM
  #81
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Originally Posted by SS RRR
In the pic? Not for me if they are.
Yeah. I guess I thought that was your car.
Old Mar 11, 2015 | 10:31 AM
  #82
SS RRR's Avatar
Village Troll
Oh, in the original pic. I thought you were asking "what's in the box!" with the latest pic. Yes those are old and haggered out Hookers I bought in 1998 IIRC.
Old Mar 11, 2015 | 10:47 AM
  #83
speed_demon24's Avatar
No thanks. It's been tainted and I actually want power without having to remove 700lbs of weight.
You might want to re-evaluate your goals. Like not having a car down for 1+ years while making it slower in the process.
Old Mar 11, 2015 | 01:22 PM
  #84
Shownomercy's Avatar
Man-Crush Warning
Shut up Richard, that was my old cam he is trying to sell you.
Went 10s NA full weight car, broski.
Old Mar 11, 2015 | 02:50 PM
  #85
SS RRR's Avatar
Village Troll
which means if i buy it and have you install it i'll be in the 9's full weight n/a.
Old Mar 11, 2015 | 03:21 PM
  #86
JasonShort's Avatar
Moderator
Let's stay constructive fellas.
Old Mar 12, 2015 | 08:51 AM
  #87
SS RRR's Avatar
Village Troll
We all just one big dysfunctional family!
Old Mar 12, 2015 | 08:54 AM
  #88
Man-Crush Warning
richard is a dick and makes lame threads, how can one be constructive, really?
Old Mar 12, 2015 | 10:10 AM
  #89
sweetbmxrider's Avatar
I love your fascination with the weight of my car. Like I pulled 700 lbs out of it magically and it would run 12's if I put the supposed 700 lbs back in. Your dumb *** should spend more time learning how to make usable power and transferring it efficiently rather than acting like a 16 year old. Good luck.
Old Mar 12, 2015 | 11:25 AM
  #90
BIGsmokey10's Avatar
I have a cam out of a 3406 CAT. Will have to chop off a couple lobes. Lmk if your interested, I'll have snm install it. 40 bucks
Old Mar 12, 2015 | 03:09 PM
  #91
SS RRR's Avatar
Village Troll
Thanks, but as already stated I'm not interested in doing anything more than fixing what is broken. It's done a fine job of transferring power efficiently at least on the low end, sir. It's the top end of the rpm band that didn't do so well, which has been explained why, and was expected from the very beginning. If you are really hurt by what has been said you don't need to actively post in this thread? Just a thought.
Funny thing the mention of 16 y/o's... Interesting how you go into threads here and talk smack about other cars, but sweet Jesus Almighty if anything is said about yours....
If it can pull a Nebraska Oak out of the ground I am sold!
Old Mar 13, 2015 | 06:47 AM
  #92
CamOnlyJabroni's Avatar
I think the cam journals on a 3406 are just hair bit bigger than a SBC too.
Old Mar 13, 2015 | 10:19 AM
  #93
You talk **** in some random thread.....
So little power, had to hack weight to run a number.
and claim I'm the one doing so? When you go out of your way to shoot down any LE based thread with which you have no actual experience with? When you are the one with the wiped out cam lobes and metal throughout your motor and mine continues to run perfect yet you talk more **** because I'm considering selling it? You need help. 16 year old girls require less attention than you. Go ahead, continue your harassing to try and satisfy some sort of personal issue(s) in your life
Old Mar 13, 2015 | 11:35 AM
  #94
SS RRR's Avatar
Village Troll
To keep this on a constructive level, the reason why there was metal sent throughout the motor was purely through neglect. As you may or may not know, because of the higher spring pressures of a SR engine the valvetrain should be regularly checked after every so often. I was all about adjusting valves and checking the valve seats and tips, but never looked at the lobes and lifters. The lifters were tall body and required the heads to be taken off in order to get the lifters out. Contrary to speed_demon's belief the engine did have a lot of miles on it, many 7200rpm shifts and had been together for seven years. So, in essence, this problem I am fixing is all on me.
Aside from that, are you saying in a round about way you would like me to stop picking on you? Is that what I'm getting with all this complaining?
Dremel out the journals?
Old Mar 14, 2015 | 06:05 AM
  #95
joelster's Avatar
So, you say it had no top end and you knew that it wouldn't, and then a few posts down you brag about how it pulled to 7200 for 7 years. Yeah that makes a lot of sense.
Old Mar 14, 2015 | 06:45 AM
  #96
SS RRR's Avatar
Village Troll
Even though this has been covered before, let me try and dumb it down for you so it does make sense. You see the pics of the heads I am using, right? You think even if peak power was at 6800rpm it was yielding the kind of flow which could be achieved with something like a ported AFR? The port work on those heads were only to accommodate a 383 using a 211/219 cam. Just because one cylinder head can produce enough flow to turn higher rpm does not mean it is doing it in the most efficient way. Does that help, or is it information overload?
Old Mar 14, 2015 | 04:52 PM
  #97
joelster's Avatar
LMAO. Are you trying to tell me that if you install better parts your car will make more power? Gee, I think you are on to something! Or are you just making excuses for your cars poor performance by blaming it on the heads YOU CHOSE in the first place? Those heads aren't even a good choice for a 383. There's a reason you don't see them around on anyone's 383-396's. Maybe a 350-355 with a decent cam, but i'm sure you already know that. Now you are on to your plan of "just getting it together to get it running again" aka-too broke to fix it the right way.
Old Mar 14, 2015 | 06:26 PM
  #98
SS RRR's Avatar
Village Troll
So much butt hurt. After these kind of frothing posts it is a wonder how you can tie your own shoes, or even breathe for that matter. Seems you are always wanting to leave details out to come up with your own conclusions. It's just weird how you can consistently be this wrong. Whatever I've done has always been about spending as little as possible. Everyone says how I must have spent a fortune for LT4 Lingenfelter heads. Not true. LPE was wanting to get rid of them in favor of R&D for the LS1 when it debuted. I got them at their cost. Regardless, I am happy with the results for what was done past and present. Pity you cannot accept that. As far as "poor performance" is concerned I am not sure where your validity is? You bought a used e-bay block. Shortly thereafter it broke and was never fixed, never a straight answer as to what went wrong and continue to post as if it's still running. Yeah, I'm ready to be judged.
Old Mar 14, 2015 | 07:57 PM
  #99
PonchoDude's Avatar
God... I hope you get that pile running soon
Old Mar 14, 2015 | 08:25 PM
  #100
SS RRR's Avatar
Village Troll
I miss Tealnet.
