trans?
Old May 30, 2014 | 06:39 PM
ss97dml's Avatar
Default trans?
Automatic 383 w procharger drives fine if not getting on it but when I do get on it it free revs and goes into neutral? Then I have to put in 2nd gear and it goes and the shifts back into drive and overdrive.any help would b appreciated..
Old Jun 5, 2014 | 03:34 AM
cardo0's Avatar
Dont know whats wrong with your trans. But my Bow Tie Overdrive level 3 has worked great for over 3 years as a daily driver. Great Price. Check'm out: http://bowtieoverdrives.com/index.shtml
Good luck,
cardo
Old Jun 5, 2014 | 07:41 AM
93M6Formula's Avatar
Was the trans built at all?
Old Jun 5, 2014 | 01:04 PM
19trans79amws6's Avatar
you may have a problem with your trans or my need your pcm tuned. I have heard
of this before and it was a tune problem. Have you changed the pcm lately. PCM forless will do a grat job for u if u need.
Old Jun 5, 2014 | 01:20 PM
nitrous2fast's Avatar
kind of sounds like the 3/4 clutch packs are out.
Old Jun 5, 2014 | 10:03 PM
NewOrleansLT1's Avatar
I really think your sprag gear is cracked..
Old Jun 6, 2014 | 06:15 AM
bowtienut's Avatar
I suspect the sprag as well.
Old Jun 6, 2014 | 07:14 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Yeah, something's not right. There's a good bunch of upgraded parts that should be used in a unit behind a boosted motor.
You'll get better & more relevant answers in the automatic transmission section: https://ls1tech.com/forums/automatic-transmission-13/
 Michael S. Palmer
