XFI 280 383 stroker
Old Jun 10, 2014 | 02:59 PM
95camaro21's Avatar
Default XFI 280 383 stroker
What do you guys think about a XFI 280 cam on a 383 stroker?
383 stroker 11.8 compression
kb flat top piston
Scat forged crank
Ported heads
XFI 280 cam
Beehive Springs
Beehive Retainers
Bbk 58mm TB
Pacesetter LT
One cat back to Borla exhaust
I had stock heads I had a friend do this work on them.
Full bowl blend, opening up the pushrod pinch and cleaning up the valve guides. Plus, deshrouding the valves. 2.00/1.56 valves.
Manley 11500-8 intake
Manley 11501-8 exhaust.
My main question is does this look like a good build?
Old Jun 10, 2014 | 05:33 PM
hrcslam's Avatar
Looks like a good combination. What's your quench?
Should be safe in Phoenix heat on 91 with a good tune.
Did you have the heads flow tested?
