random problem at 5k rpms?!?
Old Jun 11, 2014 | 10:34 AM
WCT13's Avatar
Default random problem at 5k rpms?!?
So today i was in the highway and floored my car at 50 it dropped to second amd was like vrooom (sounds like a pop and its like it was gonna cut off) then a little more vroom and some more pop with it bogging. The bogs are about 1/10th of a second long.
Could this be a spark plug problem? There was oil on the end of a few plugs. Could it be fouled out spark plugs? I need to know fast cause i got a beach trip planned saturday
Old Jun 11, 2014 | 10:43 AM
moehorsepower's Avatar
Ok not sure what vroom means, but if ur plugs are oiled fouled that is certainly one of your problems
Old Jun 11, 2014 | 11:00 AM
WCT13's Avatar
Vroom means going or accelerating i couldnt think of how to phrase it. Ill try n grab a vid real fast
Old Jun 11, 2014 | 11:39 AM
WCT13's Avatar
I do believe i figured it out. I think it's hitting the rev limiter on the 2-3 shift. Trans only has 2k miles with a 3500 stall. Cpu is from a road master in a camaro. Think I will find someone to bump the rev limiter up and increase line pressure. OR lower my shift points.
